- Sun Aug 02, 2020 4:55 pm
#2694
All this stuff too. If its not yet on the car, its still in the box. Think of it as a jig saw puzzle with extra pieces. Its all there.
86 '951 White with Maroon interior. LSD Transaxle with cooler.
Fuchs 16" wheels.
Some of the stuff no prices. Have to find the receipts. Actually have most since it was new from prior owner. Odd history. Original owner worked for Chrysler back in the 80's. Got transferred to Europe and took it along. Never registered when there. Sat then shipped back to the US again.
Parts: 9,489.46
Motor: Automotive Machine Supply rebuilt short block 2,703.73 new
Steel sleeved. Stock pistons with dry coat film.
Surface deck. Polish crank. Balance.
ARP bolts.
Pilot bearing. All new Glyco bearings.
Turbo G-Pop Shop. Hot side KKK26. Compressor
Side Garrett housing with 44 trim wheel. Upgraded
thrust bearing. 670.00 new
Studs New Porsche head studs. Ian's Euro Parts 155.00 new
Front Belts Zimms all new belts and rollers etc. etc, 334.69
Clutch Zimm's plus 930 disc 546.66 new
Adjustable fuel pressure regulator ( used) 85.00 Used
Aluminum Flywheel 100.00
Injectors Stock sent to Witch Hunter 82.00
#54 after market set 120.00
Braided fuel lines 199.99 new
AEM UEGO widebank air/ fuel guage 214.95 new
MAF Vitese maf kit with SM6 controller 1,935.00 new
Lindsey manual boost adj. 64.95 new
Boot guage new
Lindsey silicone hose kit 144.95 new
tune up Rotor cap, dust cover, Reference sensor, rotor $128.00 new
Zimms plug wiring harness $80.00 new
waste gate Tial 38mm 200.00 used
adaptor plates 128.93 new
Exhaust 3" with Borla muffler 300.00 used
Misc Lindsey Turbo oil inlet filter kit new
Limdsey Vacuum hose kit new
Gaskets etc. 213.76
Lindsey steam vent kit 39.95 new
Exhasut hardware kit 49.50 new
Zimms Flywheel bolts new
Water pump safety bar and fasteners 50.55 new
Zimms sensor sleeve 49.95 new
Paragon Throttle body rebuild kit 33.83 new
Motor mount hot side 58.00 new
Texas Rubber; Braided stainless oil lines 99.00 new
New reference sensor new
Good used AC compressor - Lart used
Shocks Koni all around, fronts mounted already 361.12 new
Suspension Aluminum upper ball mount & suspenion clip 239.95 new
Engine bay cross brace 100.00 used
Extra head, extra cam etc.
Extra oil cooler.
New wheel bearings,ball joints, bushings new
Rennlist July 28th Massacre Survivor. 2020
