- Thu Oct 22, 2020 12:03 pm
#27233
For those that your interior 997 door handle does not fully return. The retaining spring section of the handle latch has broken. Porsche has updated the design which requires the later cables to also be changed over. However something I have discovered is the retaining plastic part can be used on either side, so in my case if the passenger side one breaks, I can use the old broken drivers side on the passenger side without having to change the cable out.
Old style cable retaining hole
New style cable retaining hole
Old vs new cable. New cable is the "T" style with plastic end.
996TT | 997TT | Audi TT | Corrado SLC | Tundra | Land Rover IIA 109
