Santa got me one for the 928, where should I put the sensor?:)
The upper radiator hose location is more or less taken by the electric fan switch temp sensor already.
Lower radiator hose potentially, but I haven’t found a source for the two inch OD hose sensor ports. They must exist because Carl sold them in his kits.
Heater return line if the heater valve is held open?
Other ideas?
SeanR wrote: Fri Dec 25, 2020 11:54 am We replaced the block drain plug with a bolt that had an attachment point for a sensor. I need to find out what it was. Works very well. This was about 7 years ago and the memory fades.
Hey, that’s smart I would not have thought of that. I will look at fittings.
What did you get boss man?:)
Honda ACTY (Kei Truck)
I want one. God knows what I'd actually use it fo[…]
I believe Chris connected with 928 specialists s[…]
https://i.imgur.com/biMOPsy.jpg https://i.imgur[…]
