By Tony
#54800
Looked on PET and cant seem to find a reference to this. Two on each window and basically limit the upper and lower limit of travel on the window mechanism. They are plastic blocks that sit inside a part that bolts to the window drive.
mine are in shambles.
i have an idea how to fab up my own. I have some very hard rubber jacking pads that came with my quickjack...i could sacrifice part of the extra one i have.
are these parts available though.???
also, i found that the retaining bolt on this to be loose on both windows. This will cause the window to go beyond a normal limit and cause the door frame to flex. I saw someone make reference to that issue recently...cant recall what thread. But, this is most likely the problem causing it.
By MFranke
#54929
After trying in vain to fab some out of rubber, I replaced my disintegrated rubber stop pieces with some hardwood, cut to size. It was easier to make a good fit.
It's been about 8 years and working fine so far.
By Tony
#54976
Made my own out of some hard rubber. Basically a slice from an extra jack pad i had on my quickjack
Should work fine. It just prevents the metal arm hitting a solid metal stop.
MFranke liked this
Da 944
I hope it's got a V8 with the four exhaust tips. G[…]
928 v Z28 1983
had an 84 iroc z. balsy. broke the tires loose e[…]
I filled the ring groves with epoxy, and used the […]
^^^ Nice!!!
