maddog2020 wrote: ↑Sat Feb 13, 2021 11:19 am
yep I could tell by the pics. Unfortunately I'm intimately familiar with Fikse FM10 wheels and their fitment on a 928. The only way they fit is with a 1 inch outer lip, and because of the way the wheel center mounts its virtually flat.
If you're talking about the fronts then yeah, I'll give you that from the pictures independent of knowledge of the front widths but with knowledge of Fikse/Kodiak construction and 928s. There's little wiggle room on the front as far as sticking out is concerned.
Not the rears though. Not, *just* from pics. Now, if you already know the rear widths to the half-inch then maybe.
So when you have the 2 inch lip, no way no how are they going to fit.
My rear Fikses have a two inch outer barrel.
My GTS rears have a 3 inch outer barrel (not Fikses though.)
So: pppttthppphhht! :)
And that barely fits. Event then the tires stick out past the fender.
On the front yes. An 18x9 ET 63 will stick out by several millimeters.
But, if you're going to run 9" fronts you basically don't have a choice about 'sticking out.' If you increase the offset sufficiently to get the wheel even with the fenders you'll have considerable rubbing on the lower sill before you get full steering lock. And this assumes that with an 18" the suspension members don't interfere before does the lower sill.
Now, my front Fikses to stick out a couple of MMs, but I'm running 9" Et 68.5 (from back in the day when Fikse could do that.) A bespoke front ride height is critical to preventing rubbing on the lower sill.
Scott at Team Harco wrote: ↑Sat Feb 13, 2021 4:51 pm
I agree with maddog on this. The wheels were beautiful - but it was obvious there were going to be fitment issues.
Note that, initially, I was not arguing that the fronts or rears might not have "fit". I was arguing that from just pictures and without knowledge of widths and offsets that it is rather cheeky to declare that they won't fit on a 928.
There was too much offset. By how much, would only be known by trial fitment or proper measurement of the offset.
Assuming you have not "textually" swapped negative offset for positive offset...
From reading your post to our dearly departed I believe that you are arguing a point opposite of maddog if you refer to the front. You argue that the offset should be decreased - from 63 to say 50 - which would push the outer rim further away from the hub face and thus make it fit even less well than maddog thinks it will.
Note that Et 68 is not "too much offset" on a front 9" front wheel for a 928 so 63 isn't too much either. It's not enough offset actually. Arguably there is no correct 928 offset for a 9" front wheel if you want both no rubbing under any circumstances and no sticking out.
On a 928 S4 stuffing an 10.5" in the rear is a study in controlling offset to the MM. A 10.5 Et 54 on a 295 is pretty much the sweet spot. Decreasing offset further will result in pushing the tires through the rear fenders since the tire is above the fender level at stock(-ish) ride heights. Increasing the offset by a couple of mm will result in suspension members hitting the inner barrel. Tire choice between 275, 285, 295 also becomes critical depending upon offset. With a GT you've got roughly another 3/8" of wiggle room. And lots of folks 'roll' S4 fenders to get some more room. A GTS has about 1.5" more room outboard than an S4. The good news is that on the rear the critical suspension members don't move relative to the wheel(*) so the only thing you have worry about with cunt-hair clearance is wheel deformation under load.
(*) The upper dog bone moves but the lower control arm is the critical member.
In any case 10.5 ET 57 is not obviously too much offset and the difference between ET 54, 57, 63 (etc.) is not something you can gauge from a picture of an unmounted rear wheel.
Anyway - the point I am making, in all of this - I know what the hell I'm talking about when it comes to wheels and tires.
Note that, above, I do not cast aspersions on your general level of knowledge. I do not claim to have your level of "general knowledge" but I do know something of 928s and what rubs and doesn't rub and what I have mounted on my three 928s.
I do, however, cast aspersions on both you and maddog with respect to your ability to measure offsets to the millimeter with your mark one eyeballs especially from pictures on the interwebs.
Worf's Corollary: Once you've mitigated risk from stupidity and laziness in your endeavors, failure is usually the result of insufficient imagination.
My 928 Inspection Guide
