- Fri Mar 05, 2021 6:19 pm
#64540
Sealing washers on front brakes
87s4 with big reds
ive seen and heard two things.
#1. 1 sealing ring between the banjo bolt and the fitting as illustrated
#2. 2 sealing rings...1 between the banjo bolt and the fitting.....and....the fitting and the caliper block.
the WSM shows 1 sealing ring in the image yet describes 2 needed in the text?
Is that one on each side L and R....or ...2 on each side for total of 4.
part #14
87s4 with big reds
part #14
