#69099
So, I am removing the upper a arms to put in new shocks. In the process of removing the 22mm nuts on the inside of the fender, I noticed only one washer per driver/passenger side. I was expecting a washer for each 22mm nut. Is this correct?
By Majestic Moose
#69165
That is correct. The washer goes on the side with the bracket for the engine crossmember.
checkmate1996 liked this
#69214
excellent. thanks for the confirmation.
78-86 vs 87-95 lower rad hose
