It's our birthday!!! One year anniversary!
Yes one year ago today there was a disruption in the universe that ended up in creating this community. As promised we have winners from our Birthday Scavenger Hunt.
Go to the following link to find out who and what the final answers were:
Click here!
By Tony
#74498
how on this earth do you close this gap on the outer window trim. it's not much, but the factory installation had zero. it has to be installed at an angle due to the shape of the trim and how it extends into the upper corner. you can get it started and then bend it slightly a d it closes but not completely flush.. I've. lubed the metal... gently tapped on the other end etc. the tapping gets absorbed by the upper corner prior to this joint.
it's not. bad... but not perfect either. and I can live with it.
By Ed Scherer
#74538
It's at the back of the window, about 24 cm above (and slightly in front of) the center of the door lock cylinder.
Tony, I just looked at mine ('90 S4) on both sides, and it's not much tighter than yours. Maybe a little. But it doesn't even look as even (parallel ends) as yours. Maybe it was just the camera angle on mine.
By Tony
#74540
sean.. you probably can't see it as it's a perfect flush fit from the factory.. or... after a while that small gap just gets filled with shmutz.
meanwhile.. it's never easy when your plastic malet misses and scratches your previously applied perfect coat of SEM trim paint. :bigcry:... you spray it over but now ON the car. :banghead:
By Don Smith
#74661
Mine is pretty well parallel, also, and very little gap.
Two companies are working on making new connecto[…]
Schedule: https://res.cloudinary.com/dcx7bbpx8/im[…]
Back to work on Orangie. https://i.imgur.com/aH[…]
I'm gonna lead a cheer at the Breakfast for Maddog[…]
