By milrad
#92852
Anyone know the proper length for the vac hose running from the flappy actuator to the flappy solenoid? 89GT. I'm making up new lines and somehow along the way in this project this vac hose went missing.
Thanks!
#92857
Can't you just add 10" to half the manifold length, and cut to final size later?
Geza-aka-Zombo wrote: Tue Jul 20, 2021 10:32 pm Can't you just add 10" to half the manifold length, and cut to final size later?
This -^. 18” will be way to long (enough.) Install manifold and cut to length.
By milrad
#92861
Well that would be too obvious :roflmao:
Actually I'm working off Roger's kit and retrofitting to stock a modified vac system as I update my SC setup. I'm trying to be economical so I don't need to wait for more hose. Mostly I just prefer to do things right the first time and be done. Your way is probably better...
this long
That right-hand drive stuff is weird… :tongue:
Left-hand drive vac line from the changeover valve to the resonance flap vacuum actuator is about 10” long and the actuator is very different.
Cayenne vs panamera (hybrid)
:thumbup: :rockon: :burnout:
