I’m looking (go to) for one too. But not for engine builds.
Why do you want one?
By hans14914
#119546
I think I am down to my last original unit, and the two different prototypes I made for the Sunex stands. Unfortunately, the Sunex stands have too short a wheel base to support the 928 engine in the extended position, so I never made any more.
If someone really needs to borrow one, I can loan it out.... but not for something like a 5-year build. I have at least 8 engines here, so I will need it myself at some point.
They are pretty easy to make, and I already have the drawings. I never made or had the necessary flywheel lock tool quoted. Kind of worthless without that piece, but you often don't even see the factory yokes with the matching lock.
If I get a minimum of 5 people to commit to buying a set, I would go back and check the lock tool design and get quotes on having something made.
I have WAY too many parts on the shelf here from stuff that people said they wanted and then only sold a handful of. I honestly don't even have the room to inventory more parts.
hans14914 wrote: Wed Dec 01, 2021 10:40 am I have WAY too many parts on the shelf here from stuff that people said they wanted and then only sold a handful of. I honestly don't even have the room to inventory more parts.
Hans, you probably have stuff I’d buy in 1/2-dozen or more quantities that I don’t even know you have.
You should gather up and post an inventory.
milrad liked this
maddog2020 wrote: Wed Dec 01, 2021 9:19 am engine build.
I assemble the case on a work table and then transfer to my geared stand with my engine picker.
#119577
worf wrote: Wed Dec 01, 2021 11:05 am
+928 Hans, You should post what you DO have for sale.
maddog2020 liked this
By hans14914
#119612
Here is the 3D model of the factory part with the flywheel lock:
http://cloudviewer.spaceclaim.com/e18f6 ... f254b.html
It would only take me a few minutes to modify the design for use with a standard 4-arm stand. We just need to get a couple people interested before I go back and double check the lock tool and send for quotes.
hi Hans
i will take one, don't need it until the spring/summer, but let me know if you need a deposit on it anytime
+ postage to the UK
hans14914 wrote: Wed Dec 01, 2021 1:49 pm It would only take me a few minutes to modify the design for use with a standard 4-arm stand. We just need to get a couple people interested before I go back and double check the lock tool and send for quotes.
I’ll buy two.
By hans14914
#120176
I am looking into the flywheel lock.
I am going to order a couple off the shelf parts to see if any have the same tooth pattern. Will keep everyone updated.
