- Mon Apr 11, 2022 12:56 pm
#144694
I am well aware of the issues surrounding the head cancer problem but I have a question about it. Is there a way, short of removing the heads, that you could determine if you have a problem currently? I know its just a matter of time before you need to address the issue but the question is starting to concern me now.
I have an 89 5sp and my issue is I'm losing coolant but with no external leaks or coolant smell in the car, no white smoke but a slight temp gauge increase after about an hours city driving which I attribute to the loss of coolant. Fans are working correctly, I had the controller and Final Stage rebuilt. I did replace the coolant cap which helped but I still lose about 1 inch of coolant in the tank after a drive. Do the exhaust gas coolant testers effectively assist in diagnosing small coolant leaks that would result from disintegrating head gaskets ?
My compression is good, the engine is strong but the heads have never been off in 160k miles. What should I look for here? I have a timing belt/water pump job coming up soon so the car will be out of action for a while and I might address the issue then, depending on the advise I get. Thanks.
1989 S4 5sp Guards Red
2002 BMW M5 Titan Silver
2000 BMW 740iL Titan Silver
2015 Mercedes S550 Lunar Blue
The one I let get away: 1972 Dino 246GT
