- Sat Jun 11, 2022 9:18 am
#154496
Cold start: no problem. Car idles strong until I drive off
Hot start: after car is fully heated up and I shut it down, do my errands etc car will start first turn of the key.
However, the idle sucks and I have to feather it until I drive off. Otherwise, it will die.
So I've been doing my hot starts with the AC on to boost the RPM. This works but obviously not the solution.
I suspect a part(s) needs replacement etc. What should I look at?
No fuel found in any Damper or Fuel Reg hoses. Last year all vacuum hoses replaced and smoke test showed no leaks in system.
Please and thanks
Fred
Please and thanks
Fred
Fred
1989 S4 Koenig widebody, 6 sp-Z06
