Isolated a knocking in lower front engine at crank while getting ready for DE event.
It seems to be the lower idler. The bearings spun without noise but the carrier arm will rattle. Circlips are there but just enough laxity to rattle.
I’m sure it’s a by product of my super damper fail last week. But here’s my question: can the idler be deleted?
Or did I make that up? I seem to remember old threads on RL where people have ditched it.
What Shaun said.
I'd never delete the inboard lower idler from a client's car.
However, the second idler (present on '89+/-, I forget) can be deleted.
Got it. Thanks guys. I will shim it.
Appreciate the feedback Sean.
Dave, how is the cat BTW?
Why was it put there to begin with? There must be a good reason?
Crumpler wrote: Sun Oct 04, 2020 2:28 pm Dave, how is the cat BTW?
Good question. Thanks for asking. I'll update in the cat thread. :cat:
BTW, if you want to replace the bearing on that roller, just read off the bearing number, order a high(er)-quality bearing (~$10-20) with the same number, press off the roller shell and press-in the new bearing. That's what I do, now, for both lower idler and tension idler if the shells are still good, since the new Porsche parts are stupid expensive. For 'bad' shells I just pick out a cad-plated replacement shell and toss the old one in the to-be-replated box.
linderpat wrote: Sun Oct 04, 2020 2:32 pm Why was it put there to begin with? There must be a good reason?
AFAIK and IIRC, the purpose is to keep the belt wrapped around the crank gear in "high belt flap" conditions and also if the crank turns backwards just a bit which can happen depending upon how everything 'stops.' It's probably 80% paranoiac German over-engineering, but the low probability part might have consequences severely inimical to warranty.
911 pricing
Very specific, but if you hear of a black, PDK 9[…]
Da 944
I hope it's got a V8 with the four exhaust tips. G[…]
928 v Z28 1983
had an 84 iroc z. balsy. broke the tires loose e[…]
I filled the ring groves with epoxy, and used the […]
