- Thu Aug 06, 2020 3:56 pm
#4575
"My Posts not meant to offend and for entertainment only"
All,
I've been a Vintage Airstream nut for many years. Always fun finding these trailers and restoring them.
It is a labor of love and over the past 20 years I've really gotten to know how to restore most every failing system or structural component.
Realistically it takes about a year to restore one properly doing it on a part time basis. I find after a month it gets monotonous and you have to step away for a few weeks and then dive back in. Makes it more enjoyable.
I used to fix them up and sell them until I came across what I feel is the perfect size for 2 people.
My 1963 19' Airstream Globe Trotter is to me is a great size. Easy to tow and maneuver, will fit in most all campgrounds and easy to park at your house even if living in the city. (Try backing in a 31' trailer)
I purchase my Globe Trotter (GT)3 years ago and it was a mess. The exterior shell was nice and not many dents and the floors were mostly solid except for the front door area. Previous owner painted the interior cabinets and some were missing. Electrical wiring needed some attention and plumbing/propane systems needed replacing.
These GT's have bathrooms with the toilet on an angle directly next to the rear closet allowing for very little room - Also these GT's were not designed with a "grey water" tank - Just a black water tank for sewage. So I redesigned the bathroom cutting back the closet to a 45 degree angle allowing for much more legroom while keeping the closet pretty much intact and adding shelf above.
I also removed the huge propane furnace and hot water tank and installed an "on demand" propane hot water tank and propane heater.
As art of the bathroom design I also added a valve in the grey water drain system which diverts the kitchen sink water into the black water tank.
The original design is set up so that all sink and shower water are held in pipes until you release the water by opening valve underneath and water dump out under the trailer and or lead away with a hose.
My design allows for the kitchen sink to be used so no water dumps out of trailer and is collected in the black tank OR you can use the original setup and have it dump out thru hose. This way you don;t have to crawl under trailer every time you ant to use the sink if you are not at campground.
I like keeping design as close to original with just a few updates. I added nicer built in cooler/fridge and microwave. Also propane cooktop instead of stove/oven. I redid plumbing in copper which is like original only I added more valves to empty entire system for winter.
I also added a dinette - Original design had pullout gaucho in front and I prefer having dinette for hanging and eating/board games/etc
Here are some before and after photos.
8-)
8-)
