Car jack and tire
The Top Ten Best Portable Car Jacks
A car jack is an essential for any car owner. After all, without one, it’s extremely difficult and unsafe to lift up cars so you can change a tire or perform other maintenance tasks.
Portable car jacks are a great option for those who don’t have a lot of space or don’t want to spend the money on a bigger, more permanent one. They’re also much easier to store than a traditional car jack.
If you’re in the market for a portable car jack, there are a few things you should keep in mind. First, you need to decide what type of car jack you want. There are hydraulic jacks, scissor jacks, and bottle jacks.
Hydraulic jacks, which use a pump to lift the car up, are the most popular type. Scissor jacks are cheaper and easier to use, but they can’t lift the car as high. Bottle jacks are the most powerful, but they’re also the most expensive.
Once you’ve decided on the type, you need to determine how much your car weighs so you know how much weight you need to lift. Most portable car jacks can lift between two and four tons, but there are options for heavier cars.
Finally, you need to decide on your budget; portable car jacks range from around $30 – $100.
Once you’ve figured out the above, it’s all about finding one that fits your criteria. We’ll take a look at the best portable car jacks below so you can find the right fit for your needs.
10 Top-rated Portable Car Jacks From Amazon
1. Pro-LifT F-2315PE Grey Hydraulic Trolley Jack
Price: $47.94
This Pro-LifT F-2315PE Grey Hydraulic Trolley Jack Car Lift is perfect for car service. It has a load capacity of 3000 pounds and is made with all welded steel construction for durability. The large steel casters make it easy to move, and the sturdy handle ensures easy transport. Plus, it comes with a blow-molded case for easy storage.
2. BIG RED T10152 Torin Steel Scissor Lift Jack
Price: $20.45
The BIG RED T10152 Torin Steel Scissor Lift Jack Car Kit is a versatile tool that can be used as a replacement jack or as an extra utility jack. This jack is made of drop-forged alloyed steel for quality and durability. It has a lifting range of 4-1/8″ to 15-1/8″ with a 1.5 ton (3,000 lb) capacity. The extra-wide base adds stability and strength, and the one-piece handle delivers on-the-spot quick response and speed.
3. LEADBRAND Scissor Jack
Price: $29.90
The LEADBRAND scissor jack is a handy tool that can be used to quickly and easily adjust the height of a vehicle. The jack’s ergonomic design makes it simple to operate. The base plate provides a sturdy foundation, and the ratchet handle makes it simple to use. This portable car jack is made of corrosion-resistant steel and is both durable and robust. With a lift range of 4.09 to 15.15 inches, this portable car jack leaves plenty of room for movement.
4. Amvia Scissor Jack for Car
Price: $31.90
The AMVIA scissor jack is composed of alloy steel and can handle 3,300 pounds. The maximum lifting height is 15.15 inches. The jack weighs 5.34 pounds and fits any type of automobile, so it’s perfect for those who want a durable, versatile, and reliable scissor jack.
5. Pro-Lift F-767 Grey Low Profile Floor Jack
Price: $88.69
The Pro-Lift F-767 Grey Low Profile Floor Jack is a high-quality piece of equipment. It has a load capacity of up to 2 tons and a maximum lifting height of 14 inches, making it ideal for most situations. This jack is built to last with a heavy-duty steel construction. Additionally, it features a patented bypass device that protects against over-pumping, ensuring safe and easy operation.
6. Powerbuilt 3 Ton, Bottle Jack and Jack Stands
Price: $99.99
The Powerbuilt 3-Ton Bottle Jack and Jack Stands is a compact and convenient tool that is perfect for use on cars, trailers, and other vehicles. With the ability to lift 3,000 pounds and a range of 11 – 21 inches, this jack can get the job done. In addition, the ratcheting jack stand comes with a safety bar to avoid any accidents while in use.
7. Torin T90413 Big Red Hydraulic Bottle Jack
Price: $35.99
The Torin T90413 Big Red Hydraulic Bottle Jack is suitable for your home garage or professional car shop. Its wide, rugged base offers unmatched strength and stability. The jack meets ASME safety standards and has a lifting range of 7-1/2″ to 14-5/16″ with a capacity of 4 tons (8,000 lbs). The jack is made of drop forged alloyed steel, all stress points are reinforced for enhanced durability, and an adjustable screw top extension adds versatility. The welded inner/outer structure offers leak-free performance. The smooth, glide-action pressure pump and hydraulic system are intended to raise without much effort.
8. Jack Boss Hydraulic Floor Jack
Price: $46.99
The Jack Boss Hydraulic Floor Jack can lift up to 1.5 tons and has a lifting range from 5.3″ – 13.2″. It’s made of sturdy, drop-forged, alloyed, welded steel and is compact and easy to move with its 360-degree flexible swivel casters and rotating saddle. The single-piston quick lift pump makes raising to the desired height smooth and quick, and you can rely on this product for its safety and durability. This floor jack is perfect for most sedans and SUVs.
9. E-HEELP Car Jack Hydraulic
Price: $199.99
If you’re looking for a quality car jack, the E-HEELP Car Jack Hydraulic is a great choice. This is a versatile, electric car jack that can lift up to 11,023 pounds. It has an LED display and tire pressure indication, and it takes only 2 minutes to raise it to its maximum height. The electric car jack kit also includes a portable, ergonomically-designed electric impact wrench with two sleeves in different sizes. This makes it a fantastic option for fixing tires on many types of cars.
10. BAOSHISHAN 3-Ton Bottle Jack
Price: $49.99
The BAOSHISHAN 3-Ton Bottle Jack has a 6-1/2” starting height, making it easy to fit under most cars. The double ram and extension screw top give you three stages of lifting stroke, giving you a greater range of motion than traditional single-ram bottle jacks. The jack also comes with a carrying case, making it easy to store in your vehicle or garage.
Conclusion
These are the ten best-rated portable car jacks on Amazon. With a variety of prices, features, and lifting capacities, there is sure to be one that meets your needs.
Don’t forget to choose one that’s the right type, has the right weight capacity, and fits in your budget. Happy shopping!
Scroll to Top
