Welcome all 928 forum refugees!
#75009
This fuel pressure was found on my euro. I believe it’s a higher output regulator pushing around 46 psi. There are no markings on it either.
Who has seen this version?
#75131
I've removed several of them and put the stock ones back in due to running issues. Typically running too rich because who ever installed them didn't set them correctly. Solution for a problem that doesn't exist.
#75134
All the spark plugs were pitch black when I pulled them
#75159
Yeah - I am putting everything back to stock ... to start from there —-
By JBRob007
#75228
Everything back to stock... Sounds familiar for some reason 🤔🤔🤔
Foam Cannon and Pressure Washers
I've got a power washer but never use it for the[…]
mid intake refresh, water bridge seals
Prior to doing my intake refresh, I had a slight w[…]
Opel Ampera
Switched the tires to summer Conti Eco 6 and what […]
Duplicate post from Rennlist.... For the Fun Runs[…]
